Salta al contenuto principale
Announced February 2005, the Canon PowerShot A520 features 4.0-megapixel sensor with a 4x optical zoom lens.
11 Domande Visualizza tutte
dont keep date and time and off
It will not keep date and time. Have to set it everytime I turn it on and will just shut off sometimes
Questa è una buona domanda?
Punteggio 3
3 Commenti
I can't help, but I'm having the same problem.
da
I'm having the same issue but when it won't let me view my pictures. The screen just stays on the set time/date and won't let me do anything . Help!
da
I have the same issue. I update the date but it will not save it and will not allow me to take a picture. I have had this camera for years......never heard of coin type lithium battery (old turkey 03, above). I have fresh AA batteries installed. I am technically challenged. Help
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Denise, you should have a Coin-type lithium battery CR1220 on the circuit board of your camera. that is your RTC (Real Time Clock) battery and for as long as the battery works, your camera will retain it's settings. Including Time and date. When this battery does no longer work, you will lose the settings and have to reset it every time you start your camera. I would suggest to replace the battery. Hope this helps, good luck.
UPDATE 08/03/2018
Replacing the date battery PowerShot A510 and A520
Confirm that the camera is turned off.
Open the terminal cover and use your finger nail to pull out the battery holder.
Pull open the battery holder in the direction indicated by the arrow (1). Remove the battery by pulling it up in the direction indicated by the arrow (2).
Insert a new battery with the (-) side facing up.
Replace the battery holder back and close the terminal cover.
When the Date/Time menu appears, set the date and time.
Punteggio 3
3 Commenti:
How do I access the circuit board?
da
Ill agree with that... how do you access the battery? I knew that was t he problem but access is the question.
da
curtissfortysix directions added.
da
Hello, Not sure if all these questions have yet been answered, so I will try.
1) I have an A550 that also has been bugging me for months with the Reset Date & Time window when I power the unit on. Out of frustration one day, I pushed the menu button and the Reset Date & Time window closed. I was then able to use the camera without further issue. Keep in mind, you will need to repeat this process each time you turn the unit on.
2) In my camera, the CR1220 battery is located under the main battery access cover and inside a tiny lift out tab with the # CR1220 stamped on it.
Trust this helps.
Punteggio 0
1 Commento:
I set the time and date and it does stay till I turn off the camera. I don,t remember that happening before when I bought this camera. So everytime I turn on the camera the date and time is s et to 0000000. I have to again re set it. its a nuissance.
da
Aggiungi la tua risposta
Denise sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 63
Tutti i Tempi: 5,410
