Salta al contenuto principale
A 10.1-Inch Tablet, Android OS, v4.2 (Jelly Bean) manufactured by ASUS in 2013.
Asus tablet not charging
My ASUS ME302C tablet stopped charging the battery 2-3 weeks back. Tried various tricks but nothing worked. Finally now i am able to charge my battery by jump-start method. I removed the battery, cut the mobile charger wire, directly attached the charger wires to battery for 2 hours. This way my battery got good 40% charge. Then i put it back in tablet. And tablet worked fine.
Now the problem is the regular chargers are not charging the battery. It show the charging symbol but battery %age never goes up. Tried various adapters, wall sockets, PC/laptop nothing works.
I installed one app (current widget-battery monitor) to check battery current and found strange behavior. As soon as i put the charger (any charger) to the tablet, the current value shows 0mA, otherwise it shows 500-600mA 3.8V on 17% charge.
I think, my battery is fine as i am able to charge it with jump-start method. Also battery drains/performs normally.
Also USB Charging port should be good too (not sure on this), as i am able to transfer data through usb from tablet to computer. Plus charging symbol also shows up on tablet when the charger is plugged in.
So what is wrong, what is causing the current to read 0mA (no current) when i put the tablet to charging?
Questa è una buona domanda?
Punteggio 7
4 Commenti
25Jan 2016 Same problem. Battery not charging when tablet (AsusT100) is open. Seems to charge when tablet closed/switched off.
da
Out of 6 cables only the 1 ft asus cable charges it. ASUS T101H bought June 2017. I attached an extension (Male usb to Female) to short asus cable and that works.
da
Thanks Dan for suggestion!
Could you please describe in more detail, i couldn't follow it.
da
If usb connector and charging are good, TRY TO RECONNECT FLEX CABLE IN BOTH SIDES
from pcb board where usb power connector and than flex goes around of speaker
da
Aggiungi un commento
6 Risposte
Soluzione Prescelta
Try disconnecting the battery and testing the current coming in from the charger at the battery connector. Wouldn't hurt to try different chargers and cables also try flexing the outlet while testing .You can sometimes have a usb port that will connect to the computer and still not charge if you've ever re-soldered one of those usb connectors you know there's usually 10 pins if any one of those pins are not properly soldered down or if they've cracked or lifted it will only partially work. I'm going to guess that your missing the ground. Hope this helps
BTW it doesn't sound like a battery issue
Punteggio 5
3 Commenti:
I second this diagnosis. Most likely a disconnected pin on the usb connector NOT the battery.
da
This method didn't work. My tablet still won't charge.
da
asus tab usb piout & charging jumper ple.......
da
Get a Hardware Fix: take out the battery and replace it.
Punteggio 3
Jim, Eric - many thanks; I will give this a try.
Punteggio 2
I've found that the tablet is particular to a special charger. I've bought brand new Samsung chargers, both Fast and regular, and none charge it. It only charges with the cord it came with.
Punteggio 2
Thought it was the cable. It was power supply. I was trying to use apple iPhone power supply. Will only charge with original power supply. Wasted 15$ on a new cable.
Punteggio 1
Hi, suddenly two year old ASUS tablet wouldn't charge. Three repair shops and pc world I bought the machine from concluded the tablet battery was dead and the best option was to scrap it and buy a new one. Tablet cost me over £ 500/- that included office, more memory, charges for diagnostics etc .Dejected dumped it in my garage and vowed never to buy another tablet. After a month, someone in my dream told me that there was nothing wrong with my tablet. I opened my eyes and brushed it off as the figment of my imagination. But after a while I went down to my garage and brought the machine back. I gave it good clean and few knocks with my knuckles at the mains connection point. I plugged it into the mains and the magic happened I saw the Orange light. Few hours the machine was charged 100%. I turned it on; couldn't believe. knew I had saved my £500-00.
Punteggio 1
1 Commento:
i have the Asus vivotab note 8 same problem ... however i think it only charges properly with certain cables... maybe the electrical characteristics/ rating of the cable..
da
Aggiungi la tua risposta
Ripan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 28
Tutti i Tempi: 42,740
