How can you replace the internal storage
I was wondering if there was a way of replacing the internal storage on the s3 i9300 without having to replace the whole circuit board.
Thanks a lot
Questa è una buona domanda?
Thanks a lot
Yes and no. It would probably cost you near enough what the phone is worth to get done, it's very specialist work and not something anybody can just do, I don't even think people bother doing it because there's just no need.
If you need more storage what you can do is get a micro sd > sd converter. This is a ribbon cable that plugs into your micro sd card slot and on the other end is a slot for a full sd card, allowing you to use a 128GB sd card.
Thank you for your reply, the only problem is my s3 is currently broken as I damaged the internal storage whilst trying to install cyanogenmod. I now have an error when I boot it up saying "Encryption Unsuccessful", I have tried remounting the internal storage but got an error I have also formatted the whole phone including formatting the internal storage separately. Do you have any idea if there is a cost effective way of resolving this?
Thanks a lot
James
Does the phone boot into download mode? have you tried to do a FULL recovery via Odin, reflashing the bootloader, modem etc.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,023
