Salta al contenuto principale
Questo è un controller basato su touch-screen associato con la console videogiochi Wii U. Fu rilasciata nel 18 novembre del 2012 ed è disponibile nei colori bianco o nero. Numero del modello: WUP-010(EUR/USA/JPN)
top dc charging port broken in gamepad
Hello...I am trying to find a replacement part for my wii u gamepad...the top charger was inserted the wrong way and has snapped the charging pins in the gamepad. I can still charge it from the charger docking station. but cant use the gamepad while charging(annoying)...anyway I was just hoping you could point me in the direction of some where I could purchase the part I am looking for ..Thank You..
Questa è una buona domanda?
Punteggio 10
1 Commento
can it be fix or replaced i had this console for 11 years a
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Hey mate, its not to hard to find them (unlike a lot of console components) and is easy to replace. you can pick them up off ebay fairly cheep;
http://www.ebay.com/itm/USA-SELLER-New-W...
That was just the first one i clicked on so you might get one cheaper.
Hope this helps you out.
Punteggio 3
1 Commento:
Thank You for your answer unfortunately this one is for the bottom of the gamepad I need the little two pin socket at the top of the gamepad
da
part: http://ebay.to/1l2TLu6
guide: https://www.youtube.com/watch?v=c6_YRoLe...
Punteggio 2
@steve, did you find a solution? My kid pulled the corde and broke the pins in the top charging port. I only see the bottom one on eBay...
Should I be looking at a refurbished gamepad for parts?
Do you have any guides too for the replacement?
Thanks!
Punteggio 0
Aggiungi la tua risposta
steve sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 36
Tutti i Tempi: 12,053
