Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2375 Domande Visualizza tutte
SIM removal- More Complicated Than Expected?
Hi there -
Does removing the micro SIM card involve more than just sticking a paper clip in the hole?
When I do so, the paper clip seems to just hit a metal wall. Am I doing something wrong?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
The SIM card eject hole on the iPhone 4 is significantly harder to press in using a paper clip than the previous model. Just use a bit more force; it'll open no problem.
Punteggio 3
1 Commento:
Thank you, being a little more forceful with the pin did it!
My phone showed no sim, I removed the sim and re inserted it and now it works fine!
da
According to what I can find on this it should remove the same way as the prior iPhones sim card. A paper clip should be a decent substitute for the sim card removal tool that came with the iPhone.
The following article is from Apples knowledge base and has a guide as to how to remove a sim card.
http://support.apple.com/kb/ht1438
Punteggio 1
Aggiungi la tua risposta
Jeremy Anderson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 167,726
