Salta al contenuto principale
Guide di riparazione e informazioni di smontaggio per i telefoni cellulari Samsung basati su Android, vecchi e nuovi, compresa la popolare linea di prodotto Galaxy. Cerca tutto il materiale necessario per riparare da te il tuo telefono Samsung.
13180 Domande Visualizza tutte
Samsung Infuse 4G digitizer will not respond after screen replacement?
I recently purchased a replacement screen for my samsung infuse i997. I installed it and it powered up, and the home, back menu, and search buttons work. But the touchscreen will not respond
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Jeremy, always double check your work, make sure all connections are properly made and cables are properly seated. If none of that works, you may have gotten a bad assembly. Return it and replace it once more. this is not uncommon. Of course, this is only if the touchscreen worked before you replaced the assembly. Since you did not tell us why you replaced the original, I can only assume that it did work.
Punteggio 0
2 Commenti:
Screen was broken from dropping it
da
I have recently replaced the screen, after it was damaged from dropping, but the touch screen doesn't work. Phone powers up but screen is unresponsive. Help!
da
Aggiungi la tua risposta
Jeremy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 190
