Salta al contenuto principale
Modello A1136 con 30, 60, o 80 GB di hard disk con plastica frontale bianca o nera
797 Domande Visualizza tutte
When I plug it in, get apple logo and sad face
The iPod won't turn on, when I plug it in, it says the battery is extremely low then after a while it comes on but only goes to the apple logo, then to the sad mac then back to the apple logo then to the extremely low screen etc.
I was told by the folks at the apple store that it was a bad HD because I ran with it. I replaced the HD and the battery but I still have the same problem.
I was apple to sync it once before I replaced everything. It worked, but the next day, it said the battery was extremely low. I let it charge overnight, no change
Is it time for a new logic board? I replaced everything else.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Here's Apples answer to your sad face: http://support.apple.com/kb/HT1378
Punteggio 1
1 Commento:
When I plug the iPdod into my computer the apple logo comes up and stays up. I can't go into disk mode, but it will reset if I hold down the menu and select buttons.
da
Aggiungi la tua risposta
craigbrowning sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,640
