Salta al contenuto principale
Repair guides and troubleshooting for HP Pavilion dv7 laptops, manufactured by Hewlett-Packard starting in 2008, and featuring a 17.3" diagonal display.
137 Domande Visualizza tutte
Broke the lock, that connects the keyboard to the motherboard.
I was trying to open up my laptop a while back and when I was putting everything back together I broke the lock that connects the keyboard to the motherboard. Is there anyway for me to reconnect my keyboard?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
What you're looking for is called a "retaining clip", though I'm seeing them more often called a "cable clip". These aren't usually considered "replaceable" parts, as they're so fragile. However, I have seen various ones on eBay. The dv7 is common enough, you should be able to find one (I struck out). I warn you, however, that you run a pretty big chance of breaking the replacement as well while attempting installation. It's probably worth it to get the system running again, I just wanted to make sure you understand the risk.
Good luck and make sure you let us know how it turns out!
Punteggio 2
2 Commenti:
Do know about the cable clip for connection the mouse to the motherboard on a hp 8560w elitebook.. and the clip for connecting the buttons on the to the mother board?
da
While the answer I gave was in response to someone asking about a specific model series, the answer applies to all laptops (and many/most mobile devices). Just search "cable clip" or "retaining clip" along with your specific make/model, or better yet, the part number of the board to which the connector itself is soldered. I haven't looked lately, so I don't know how much luck you'd have, but it's worth a shot. All warnings and cautions also still apply.
da
Aggiungi la tua risposta
Jose sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,107
