Salta al contenuto principale
The Canon EOS 40D is a 10.1 MP digital single-lens reflex camera released in August of 2007.
14 Domande Visualizza tutte
17-85mm has the zoom ring blocked.
The zoom ring on my lenses just got blocked. Camera didn't fall down, I grabbed it out of the case and suddenly I can´t zoom in over 17mm on. I don't wanna force it but I am sure this is a solvable problem.
Thanks!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
This is a common problem with that particular lens. I experienced the same after reassembling my lens, when replacing the aperture flex cable (another common problem). Usually this is due to a single screw inside the lens that is blocking the zoom mechanism, and it is not possible to fix without disassembling the lens - which is not trivial.
There are several posts on different forums regarding this particular problem - and there's even the following video tutorial: https://www.youtube.com/watch?v=qml1ukgm...
Punteggio 1
Aggiungi la tua risposta
me sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 9
Tutti i Tempi: 657
