Salta al contenuto principale
Processore dual core Intel Core i5 da 2,5 GHz (3,1 GHz con Turbo Boost) con 3 MB di cache L3.
265 Domande Visualizza tutte
Domanda Chiusa
What screwdriver do I need for 2.3 and 3.0 mm pentalobe screws?
What is the pentalobe screwdrivers size? Such as P4, P5. For the lower case of late 2012 MacBook retina.
I don't see anywhere stated there needs to be 2 kinds of drivers, and where are the specific screws located on the panel? Please put diagram for different sized screws on the same panel
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
You'll need a P5 Pentalobe screwdriver and look here at Step 1 - MacBook Pro 13" Retina Display Late 2012 Lower Case Replacement for the different screws locations.
Punteggio 3
3 Commenti:
If this answer answered your question please remember to rate (score) and mark it accepted.
da
the p5 pentalobe works on both size 2.3 and 3.0 screws on the lower body?
da
Yes, the bottom cover case screws are the same head, some are just longer.
da
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 3,395
