Salta al contenuto principale
Domanda Chiusa
MacBook Air Error installing OS-X
My Macbook air gives me a error and it keeps saying to try the installation again, it keeps doing the same thing... tried to install leopard, snow leopard and even lion and none of those attempts work!
Questa è una buona domanda?
Punteggio 0
4 Commenti
Can you give us your systems serial number so we can identify which model you have.
da
Model # A1304 Serial number W892421G9A5
da
also want to add that i tried installing OSx from an external dvd and at some point it lets format the hard drive and lets me do whatever needs to be done at the disk utility screen and when its ready to install the software the installation stops
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I suspect your HD is going. You'll need to run a better HD diagnostics on the drive to be sure. I would recommend getting Drive Genius 3 as it can also do a deeper reformat as well
Punteggio 1
5 Commenti:
any suggestions where i can get that software?
da
Click on the Drive Genius URL I posted in my reply or goggle it. It's around $100 US well worth it's cost!
da
ok thanks so much do you think i should try to get a new hard d rive since the one i got i bought it from amazon and chances are is not good
da
Was this a new drive or used? It's possible the drive is bad. It could also be a bad low level format DG can fix. Either way is a gamble.
da
it was a used drive but ill give it a try thanks for the feed back
da
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 886
