Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
How to replace/desolder iPhone 5 SIM card reader?
Hello,
My iPhone 5 always seems to say "No SIM" even when inserting several SIM cards and cleaning the tray and internals. I strongly believe this is a SIM card reader fault, hence please may I ask how I would do about de-soldering and soldering on a new SIM card reader on the iPhone 5?
I looked at several resources online and they have given me a general idea since there aren't many guides online, hence could I please ask you guys for more specifics on how-to? I apologise for the bother.
Thank you ever so sincerely! :)
Questa è una buona domanda?
Punteggio 8
Aggiungi un commento
6 Risposte
Soluzione Prescelta
Alright, I guess I'm gonna throw my hat into this crisis of misinformation. So, OP, if you don't have a smd work station and experience in soldering, this is not for you. What you should do is look into a GOOD board repair shop that can do this, and if that's worth getting a used iPhone 5. The phone that's next on the list to become extinct. Sounds like a $75 purchase on Craigslist. This particular repair would be difficult, especially because of the plastic components. I do have a technique for this, but still, not easy. Not for a beginner for sure. The only person who made an ounce of sense was that David F guy. The rest are not things that remotely make sense
Punteggio 1
Risposta Più Utile
It is not an easy task the problem are the 2 solderpads hidden under the sim contact made in a plastic frame
Punteggio 3
If you have to ask i don't think you will be able to do it, it's not easy to resolder such a tiny component. My bets advice to you is get an old circuit board, I use a RROD Xbox 360 and practice soldering onto it.
Punteggio 1
https://www.youtube.com/watch?v=7o6f_zq2...
This video showed it pretty good for me atleast! Hope you all the best!
Punteggio 0
That video didn't show how to do anything. However, I just started looking into this but I imagine you wouldn't actually "solder", you'd use a heat gun. Any time there's multiple solder points, it's usually best to use a heat gun to soften the solder.
Punteggio 0
I suggest to bring the unit to iPhone service center and let them fix it for you.they were more competent than us since it was their kind of job
Punteggio 0
2 Commenti:
How much would that cost?
da
They don't microsolder at Apple. They sell you a new phone
da
Aggiungi la tua risposta
Arif Ullah sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 24,862
