Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Power and home button not working due to battery replacement?
Today I changed my iPhone 5 battery without a problem at all, everything went really smoothly! I don't think I used too much force to pry the phone and overall it didn't take me long. Upon trying to power the phone, it wouldn't work. I plugged the charger and it began to charge since the battery was dead. But the power and home button are not responding. I tried to see if anything looked out of place and everything seems fine. Even the volume buttons work perfectly. I'm concerned and before I consider taking it to a repair shop, I'd like to know my options if anybody could help. Another question could be the price range of the repair too.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Hello this is pry damage I bet you prayed the battery out from the motherboard side..
You have knocked conmponants off the board and unless you have soldered knowledge then you won't be fit to repair..
Mail jessabethany@gmail.com she can fix this issue
Punteggio 0
Aggiungi la tua risposta
Carla Gorritti sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 58
