Salta al contenuto principale
A touchscreen smartphone made by LG released in September 2013 with the model number VS980.
LG d802 lcd replacement!
Hi everyone,
I have a LG G2 D802 to repair with broken screen and I just recently bought a digitizer & lcd assembly based on the model number written on the phone's battery door. Part that I received has shorter connector compare to the original LCD connector. I saw G2 D801 has same connector as the phone that I have but battery door on the phone says that it's the D802 . I really appreciate if some one can tell please how to find out what LCD I should get for this phone
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
can you show the part's picture, seems you got the wrong LG d802 LCD
Punteggio 0
Perhaps you should buy a new original LCD replacement.The one you bought doesn't suit your phone. DBX provide original LCD replacements and the price is reasonable.You can have a view on its' website
Punteggio 0
1 Commento:
DBX makes wholesales which makes it cheap, so it is not for regular users.
da
Apparently the longer connectors come on the cdma versions, LS980 and LV980. So the GSM screens don't work with the CDMA boards. From what I've seen it looks like some GSM models, the newer ones also use the longer connector. This is a good place to puchase.
https://www.gounlock.com/details.php?ite...
Punteggio 0
Aggiungi la tua risposta
Ehsan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 933
