Salta al contenuto principale
The HTC One (codenamed M7) is HTC's 2013 flagship smartphone. It features a seamlessly designed unibody aluminum frame, large dual front-facing speakers, and a 4.7-inch 1080p display.
149 Domande Visualizza tutte
Broke LCD PCB connector, no display, device still powers on
I accidentally broke off a small portion of the M7's LCD PCB connector (not sure what is the correct name for this).
I put everything together again, it still boots, but does not have any screen. Fortunately I can still use ADB so most of that side appears to be working fine.
Upon closer inspection, it looks like one of the connector pins are missing from the connector:
I am not sure how to proceed from here - is it possible to get a donor board and replace this part, or do I need a new board?
Thanks for your response!
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Vic, yes you will have to replace the connector. If you have the tools and the skills to do some very fine soldering, you could do a transplant from a donor board. If you do not, you know you will need a new board.
Punteggio 0
Aggiungi la tua risposta
Vic sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 263
