Salta al contenuto principale
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
Why is there a serial number in my new lcd display?
I have just received my new lcd display that I have recently order from ifixit last month (11/25/014)for my ipad mini, the repair went smoothly with just a few minor set back. After the installation
repairs, I turn on the unit, it power up the apple logo appears, no problems whatsoever. But I notice something. Half way down in the right side of the display, there appears a four digits, numbers 4904T. Thinking that I probably forgot to remove a protective sheet
from the display, remove the digitizer and check for the protective
sheet, but did not find any on the display. I have also check
the digitizer glass, but found nothing. Just to be sure, l turn on the
ipad without the digitizer glass, and chech the lcd display, the numbers are still showing on the screen. I have also open other
programs, like safari, apps, utilities, youtube and games, with the same results the numbers are still showing. Is this normal for a new lcd, if not how could I resovle this issue. Thanks.
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
2 Risposte
Risposta Più Utile
The lcd should always have a protective sheet on it sometimes it doesn't look like it because it's on very smoothly. Take a thin blade and try a corner.
If no luck then try some alcohol on the numbers and it should wipe off.
Punteggio 3
1 Commento:
Its on the front side facing the screen had the same problem its clear and looks like its part of the lcd
da
Is the character color for the visible serial number written in red? If so, I had the same situation and it was the protective screen cover. As ‘con’ stated all you need to do is remove the protective film.
Thanks
Punteggio 2
1 Commento:
you're a life saver dude
da
Aggiungi la tua risposta
ramoncastro12 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 2,190
