Salta al contenuto principale
Model M7572 / 400 or 500 MHz G3 processor
Motherboard replacement.
Is it possible to get to the motherboard to remove and replace, from the rear of the powerbook? All the instructions I see are ones that you have to Start at the top. That seems like a lot of work just to replace that board.........? Thanks, Bob
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
3 Risposte
Risposta Più Utile
Unfortunately, it's not possible.
Apple goes back and forth with machines on making the upper case or the lower case the "base" of the machine. WIth the Pismo, everything is screwed into the lower case. It is impossible to remove all these connections from the bottom, as all the screws are accessed from the top.
Sorry!
Punteggio 1
From the top's the only way to go I'm afraid! It shouldn't be too hard, just follow the guide. (Watch out for step 41!)
Punteggio 0
Thanks to all that posted here re: getting to the Logic board from the rear, rather than from the top. I have the take apart manual, but will have a techie do it for me. Thanks again, Bob
Punteggio 0
Aggiungi la tua risposta
bobpal sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,182
