Salta al contenuto principale
A portable, rechargeable jumpstarter that can provide instant jumpstarts for cars and trucks.
charge in car with inverter
Is there any reason a driver with a jump starter power station could not use an inexpensive (read modified sign wave) inverter to keep a jump starter topped off. Mostly I need to know to use this to power a CPAP. I know this will use more power than a straight cable, but the indicator lights work with AC
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
it should work as long as the wattage of the jump box is less than the normal output of the inverter. Also, make sure you are running the engine when using the inverter as it will drain your chassis battery.
Punteggio 1
Aggiungi la tua risposta
andre sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,398
