Salta al contenuto principale
Guide di riparazione e informazioni per il disassemblaggio per i laptop prodotti da ASUS.
2519 Domande Visualizza tutte
Why is my laptop booting into bios?
The laptop is an X522e. It is three months old.
My desktop froze and I couldn't get to the start menu to reboot normally, so I held down the power button to turn it off. Not everything was frozen. I just couldn't get task manager to come up. Upon restarting it goes straight into bios. I exit bios and the computer restarts, a hash comes up, and it boots right back into bios. Now Windows apparently won't load. It's 8.1. So far I have had no problems with the machine. I had just finished working on a project for school and this happens. Any suggestions? I'm having a heart attack right about now.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi Zachary, If the information is extremely important,I would bring it to a local reliable computer repair store so they can attempt to transfer your data to a external hard drive or possibly fix the issue all in one. Hopefully your data is not corrupt and is retrievable.
After you attempted to save the data you need to try and re-install windows from bios. Your OS may have just crashed. Keep in mind when doing this your going to loose your data. Hopefully just re-installing your OS will solve your problem. It would be a good idea to run a test on your Hard drive too. You can do that with the computer if the OS re-install works, it will be under your main search options as HDD alert or HDD information. You can also use a Hard drive transfer machine to test the Hard drive.
But it may not be a good idea to remove the hard drive, since you have only had it for 3 months, you may void a manufactures warranty my removing it. If your computer has serious problems and the anti-tamper stickers are voided the manufacture maybe reluctant to help you if its a manufacture defect, if you choose to send it back of course.
Hope this helps some.
Best Regard
Josh.0
Punteggio 3
How do you """ BRING"" it to a local reliable computer repair store since YOU ARE NOT THERE ALREADY ?
English my man !!!!!!!!!!!
Punteggio 0
Aggiungi la tua risposta
Zachary sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 32,575
