Salta al contenuto principale
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 Domande Visualizza tutte
Problems of my MBA usb port
Hi, everyone. There's should be 4 metal sticks lying in the right USB port. But 3 of them has been totally bent. I can't plug in any USB devices in it. How can I fix that? Should I fix that or replace that? If I need to replace that, it seems I cant find any parts related to the right USB port, what should I get?
Thanks for you help!!!!
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
You don't. USB port/logic board repair is not a DIY project. Soldering and repair of components on logic board requires special tools, solder & lots & lots of practice.
A service (computer or small electronics) might possibly repair the port, depends on how bent/damaged the port actually is.
You could replace the entire logic board (an advanced DIY project) as you completely disassemble then reassemble the box
If this answer is acceptable please remember to return and mark it accepted.
Punteggio 0
Aggiungi la tua risposta
Mike Choy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 68
