Salta al contenuto principale
Lanciato nell'aprile 2010 / processore Core i5 2,4 o 2,53 GHz o Core i7 2,66 GHz
590 Domande Visualizza tutte
No Display backlight on the 2010 MBP 15. Options?
Hi!
I got this computer from a friend and he claims the backlight doesn't work. I tested this out to be true by
1) Booting the computer to external display. Works alright
2) Shining a light to the display shows stuff = Data is sent to the display, but backlight doesn't work
I tried cleaning LVDS cable connector on the board and LVDS cable itself but to no avail.
So what could I do? I'm guessing that the LVDS cable could be at fault but also the backlight controller on the board, but I can't for the life of me locate it or find some info on the internet. I could only find where's it's located on the 2009,2011 and 2012 computers but not on the 2010 ones
Here's a picture of the board
By the way. The guy is a heavy smoker, and I found a lot of yellow and orange dust inside the fans. It could also damage the components, maybe
Thanks for any help!
Questa è una buona domanda?
Punteggio 0
1 Commento
What number is your logic board? Should be starting with 820-xxxx and be on the board itself. You will also have post images of both sides of the board.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Marhowl, I'd start by checking the fuse for continuity. Let us know what you find
Punteggio 3
7 Commenti:
I got to get my hands on some multimeter, since I don't have one.
In any case, thanks for showing me the location.
Could it be this component? http://www.ti.com/product/LP8550/datashe...
da
Yes it could be. I will get you the proper info in a few hrs. did you get the numbers I requested in the comments? that way I can make sure it is exactly what you need.
da
I have found this number on the LB
Apple 2010 820-2850-A
Do you still wan't the pictures? I have found the piece to be called LP8545SQ from Texas instruments btw =)
da
No images needed unless you need to further identify any components,. The LED driver is indeed a LP8545SQX. Great job...
da
Alright. So what now? Should I check for continuity on the components and get back to you? Could take a while. I'm a newbie without multimeter =/
da
Mostra altri 2 commenti
Aggiungi la tua risposta
Marhowl sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,365
