Salta al contenuto principale
Processore dual core Intel Core i5 da 2,3 o 2,6 GHz o quad core Intel Core i7 da 2,7 GHz (fino a 3,7 GHz con Turbo Boost) con 6 MB di cache L3.
Battery is not recognized after replacement
I replaced the battery on my mac and it seems it does not recognize the new battery. It only works when the magsafe is pluged in. If i remove the magsafe it shutdowns immediately. The percentage of battery stuck on 62%, it says is not charging, and power source: power adapter.
Battery Information:
Model Information:
Serial Number: D86241131JYDNMGAH
Manufacturer: SMP
Device Name: bq20z451
Pack Lot Code: 0
PCB Lot Code: 0
Firmware Version: 511
Hardware Revision: 000a
Cell Revision: 1150
Charge Information:
Charge Remaining (mAh): 4974
Fully Charged: No
Charging: No
Full Charge Capacity (mAh): 8414
Health Information:
Cycle Count: 6
Condition: Replace Now
Battery Installed: Yes
Amperage (mA): 0
Voltage (mV): 11490
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 0
Disk Sleep Timer (Minutes): 10
Display Sleep Timer (Minutes): 0
Wake on AC Change: No
Wake on Clamshell Open: Yes
Wake on LAN: Yes
AutoPowerOff Delay: 14400
AutoPowerOff Enabled: 1
Current Power Source: Yes
DarkWakeBackgroundTasks: 1
Display Sleep Uses Dim: Yes
GPUSwitch: 2
PrioritizeNetworkReachabilityOverSleep: 0
Standby Delay: 4200
Standby Enabled: 1
Battery Power:
System Sleep Timer (Minutes): 10
Display Sleep Timer (Minutes): 2
DarkWakeBackgroundTasks: 0
GPUSwitch: 2
Reduce Brightness: Yes
Standby Delay: 4200
Standby Enabled: 1
Hardware Configuration:
UPS Installed: No
AC Charger Information:
Connected: Yes
Wattage (W): 85
Family: 0x0085
Serial Number: 0x00425911
Charging: No
Questa è una buona domanda?
Punteggio 6
1 Commento:
smc and all those reset stuff did not worked
da
Aggiungi un commento
2 Risposte
Try an SMC reset?
If you have already done so. and, this is not an Apple battery it could be bad right out of the box (it's been known to happen). Talk with your vendor about this.
If this answer is acceptable please remember to return and mark it accepted.
Punteggio 0
Macbook Pro Retina mid 2013. Had very same issue. New battery would not get recognized, computer would shut down after unpluging magsafe. What interesting is that if I would boot it with magsafe connected, and disconnect magsafe once apple logo appears, it would keep booting, and then right before OSx login, it would shut off.
After hours of trial and error , I booted mac with my old battery, logged in. Then, disconnected battery while mac still runs on the magsafe. Then connected new battery and this solved a problem. Battery recognized and showed me cycle count of 1.
Note, when I disconnected the old battery, while magsafe still connected, mac vent to sleep mode, but I proceeded with connection of the new battery while it was still plugged to the magsafe. Hope this helps.
Punteggio 0
Aggiungi la tua risposta
Aris sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,242
