Are they any water moisture detection stickers inside the phone
Water moisture sticking inside the Samsung Galaxy S5 as well as the one in the battery compartment
Questa è una buona domanda?
Not that i've ever heard of. Moisture detectors are usually found inside the battery compartment and inside the headphone jack. There would really be no need to place one inside the phone. You would have to completely disassemble the phone to check it. And chances are, if your phone was exposed to enough moisture to activate an internal sticker, at least one if not both of the external ones would be activated as well.
what if condensation or water vapour triggered these sensors that are exposed externally, but its no water has actually entered inside the device, then these external stickers are a slightly misleading
They are misleading, but I think that's the point. The only reason they're there is to give the techs a way to weasel out of repairing your device while it's still under warranty (at least in my experience). Say you have a device that's acting up and needs repair. You take it in and the first thing they check are the moisture sensors. Even if it's still under warranty, if those sensors are activated they will claim it's water damage which isn't a manufacturer default and will refuse to fix it.
Even if your device has never been anywhere near water. Nice little trick huh. I've even heard that just having your device (say a phone) in the pocket of your pants on your bathroom floor while you take a shower is enough to activate the sensors due to all the moisture in the air.
Anyway, just my two cents.
Whao whoa whoa. Hedphone jack? That's balls deep in the motherboard of every phone I've disassembled so far. Is it near the jack, or physically inside it? If the latter, without a magnifying glass how would you even see it? In either case, that's still "inside" the phone for all intents and purposes.
Thats the reason as to why I am asking for any internal detectors as my external one has ben partially activated only 1/5 of the indicator as turned light pink. Thanks for your answers.
The phone should have one behind where the battery is and the battery should have another one
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,138
