Salta al contenuto principale
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Domande Visualizza tutte
Stuck tri-point trackpad screw
Step 10 in the Trackpad Replacement Guide says "Remove the six 1.4 mm Y0 Tri-point screws securing the trackpad to the upper case." Unfortunately, one of these tiny screws seems to be jammed in its hole in the trackpad, and the three-lobe cut in the top (where the Tri-point Y0 Screwdriver fits) is stripped out, so the screwdriver can't get enough purchase to turn the screw.
Anybody have any suggestions for how to get this screw out?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Here's a lot of possibilities.
If this answer is acceptable please remember to return and mark it accepted.
Punteggio 0
1 Commento:
Thanks for the tips. Unfortunately, I don't have the tools, and anyway these screws are so tiny (1.4mm "long") I don't think any of these tactics would work. I'll see what I can do.
da
Aggiungi la tua risposta
HandyMac sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 561
