Salta al contenuto principale
Repair and disassembly guides for Lexmark printers.
Lexmark Genesis s816 has slowed to a crawl
After several years of very successful use, my multifunctional device slowed to a snails pace when printing anything. It takes over 4 minutes, for example, to print a test page. What could be the problem?
The device is running the latest firmware.
Thanks, Anna
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
HOW TO FIX LEXMARK GENESIS SLOW PRINT
I have also had a lot of problems with slow printing of and on. Never had time to look into the problem until now.
- First try closing network/wifi connection via the display on the printer.
- Power off the printer.
- Close any wifi or other network connections you have been using for the printer. Like a router, mobile device etc.
- Use the USB cable ONLY for printer connection.
Now power the printer on again.
- Make sure the wifi-icon on the display HAS the yellow triangle warning. If not start over again from top.
- Test printing again.
If the problem persists update drivers etc.
Punteggio 1
Aggiungi la tua risposta
belkjab sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 261
