Salta al contenuto principale
Processore dual core Intel i7 da 2,2 GHz (Turbo Boost fino a 3,1 GHz) o quad core Intel Core i7 da 2,5 GHz (Turbo Boost fino a 3,7 GHz) con 6 MB di cache L3 condivisa.
How to re-solder the headphone jack
In iFixit's late 2013 teardown of the 15" macbook pro retina, it was mentioned that the headphone jack is susceptible to breakage because it's now soldered onto the logic board. Has anyone experienced the headphone jack breaking? And how would one go about soldering the headphone jack back on? Can you use the same jack or do you have to get a new one? I haven't seen the jack for the new retina's available for purchase anywhere. Thanks.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Logic board component soldering takes special tools and lots of practice. Unless you do this for a living you should probably hire a computer repair/small electronic repair shop to do the work.
Depending upon the state of the jack when you notice the problem it may be reused, or need replacement.
If under warranty I'd take the box to apple.
A workaround would be to use a USB audio dongle. . .
If this answer is acceptable please remember to return and mark it accepted.
Punteggio 1
1 Commento:
A USB dongle is what I chose to do. It is ugly and obtrusive but also less than $15 compared to a new $900 logic board or headphone port solder which would be at least $150 if a local repair tech can do it.
da
Aggiungi la tua risposta
George Valkhoun sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 470
