Salta al contenuto principale
Released in 2004 and identified by model number J3680. Compatible with Windows 2000 and newer software, and with OSX 10.3.8 and above.
How can I get my scanner to print a PDF?
The only files that are available are BMP, JPG, PNG and TIFF. Am I able to print a PDF? If so, does anyone know how I can do that.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
See if this answers your problem: Officejet J3680 scan to PDF option missing
Punteggio 1
The most common cause of this issue is you may have the basic driver installed (which does not support PDF scanning), rather than the full feature software and driver installed. To install the full feature software and driver, go to the hp website:
http://h10025.www1.hp.com/ewfrf/wc/softw...
Then, select your operating system (windows xp, windows 7, windows 8, etc), click next, scroll down until you see "drivers", then select "download."
I hope this helps!
Punteggio 0
Aggiungi la tua risposta
Marisa sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 230
