How do I remove the washer fluid tank for repair or replacement
I have an 03 Nissan Altima 2.5s . I am trying to figure out the correct way to remove an install the washer fluid tank for repair or replacement
Questa è una buona domanda?
Eric constazzo, try this from the service manual:"
Removal and Installation for Washer Tank
1. Pull out washer tank inlet.
2. Remove fender protector,
3. Remove front washer motor connector and washer fluid level
sensor connector (if equipped).
4. Remove washer tank screws.
5. Remove washer hose, and remove the washer tank from the vehicle.
CAUTION:
After installation, add water up to the upper level of the washer
tank inlet, and check for water leaks.
Washer tank installation screws
Removal and Installation for Washer Motor EKS003H6
1. Remove fender protector,
2. Remove front washer motor connector and hose.
Tightening torque: 3.9 - 5.0 N·m (0.39 - 0.52 kg-m, 34 - 45 in-lb.)"
Hope this helps, good luck.
Thank you !! that's exactly what I was looking for
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,580
