Salta al contenuto principale
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 Domande Visualizza tutte
Maximum drive capacity in optical bay?
I'd like to replace my current 2TB HDD with a small SSD and replace the optical drive with a HDD. Is there a maximum capacity of drive I can fit in the optical bay? I've seen a 2.5" WD 2TB that I'd like to fit, would that be ok?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The limit here is the drives height. Some carriers can support a 12mm drive most can only support a 9.5mm. As we don't know the given holder or drive details (can you give us what you are getting) I can't offer you more.
You may want to think this though again. One of the issues you will face is the drive's SATA I/O speed. Remember the optical drives port is IDE not SATA so what ever drive you put into it it will be slow and you may in fact have an issue if you put in a SATA III (6.0 Gb/s) HD as many of these converting holders SATA port is only SATA I (1.5 Gb/s) or SATA II (3.0 Gb/s) so the drive may fight the SATA port as well.
If you want speed how about swapping out your HD for a SSHD (hybrid drive) Then you get the zip of the deep SSD cache with the storage of the HD. If you need more space they even have 3 & 4TB SSHD 3.5" drives! Checkout Seagate's drives.
Punteggio 1
Aggiungi la tua risposta
Anthony sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 157
