Salta al contenuto principale
AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
65 Domande Visualizza tutte
Domanda Chiusa
magsafe 2 replacement not charging
hello guys my magsafe 2 replacement don't work properly.
when i plug i get green led but after 2,3 second he turn off and start looping without charge the battery.
seems like not the connector... bad quality replacement?
its just 8mouth old.
any help is appreciate
really thx
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hi lapo,
If there's no kind of warranty on your adapter, and the company you bought it from can't help you out, there's no harm in opening it up (if you're just going to throw it away). You may be able to do some exploratory surgery by checking out our Apple AC Adapter guides. Best of luck!
Punteggio 1
1 Commento:
yeah i will try to change the cable in a old 85w... thx
da
If you are trying to contact iFixit because you bought the part from them you're in the wrong place. This is the volunteer iFIxit self-help forum, we are not affiliated with iFixit in any way. Use the link at the bottom of the page to contact iFixit customer support.
If you did not buy the part here I would suspect your battery before a part that worked fine for 8mo.
If this answer is acceptable please remember to return and mark it accepted.
Punteggio 0
3 Commenti:
off course not, just buy on ebay.
with original magsafe 2 of my girlfriend everything is work fine.
da
You get what you pay for, and pay for what you get... cheap is . . . cheap I guess you'll get a replacement somewhere else?
da
i will buy original, the price is 4 time. thanks
da
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 321
