Salta al contenuto principale
The Moto G is Motorola's economically priced phone. It has all the features one could want in a smart phone, for half the price. Model numbers XT1032, XT1033, and XT1036.
86 Domande Visualizza tutte
My phone keeps turning off on me. Could this be my battery?
Every time that I use my Motorola Moto G, the phone continues to shut off on me. I was wondering if this could be an issue with the battery. Can you please help me figure out if it is the battery or should I get a new phone?
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
3 Risposte
Soluzione Prescelta
First check and see if your phone is still under warranty. If so take it in for repair or replacement. If not you want to completely shut down phone and restart. Then allow phone to charge all night, be sure all connections from phone to charger to outlet are complete. If the issue persist it could indicate the battery needs replacing.
Punteggio 1
Risposta Più Utile
It could be your battery. If not, make sure the phone is turned off while charging. Also, if you are not getting a good signal your phone will use up extra energy searching for a signal. If this is the case, see the iPhone dealer. Good luck. Bob
Punteggio 1
My turn off and on all the time not charge is ok
Punteggio 0
1 Commento:
My phone self on and off know not charge lead new one
da
Aggiungi la tua risposta
Matthew Byram sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,877
