Salta al contenuto principale
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 Domande Visualizza tutte
swap logic board
Hey everybody, I have MacBook Pro late 2008 W88481J11GA
and I was also wondering if I could upgrade it with a 2.8 GHz logic board. LOGIC BOARD 661-4836 AS-IS
Firstly - would it make it run faster? Secondly - are the graphics better on that logic board? And where can I aquire it?
Thanks
Questa è una buona domanda?
Punteggio -1
1 Commento
Edward, the difference in processing speed will be at most in milliseconds and most likely not be noted by you. Same with the graphics.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Yes - all the '08 logic boards start out from the base model and are then customized or upgraded with faster processors and graphics. So if you can locate a good board you could go 2.8 or even 2.93.
If this answer is acceptable please remember to return and mark it accepted.
Punteggio 2
Aggiungi la tua risposta
Edward sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 105
