Salta al contenuto principale
Modello metà 2010, A1278 / processore Core Duo 2,4 o 2,66 GHz
794 Domande Visualizza tutte
Replacement screw for MacBook Pro trackpad clicker adjustment screw
While trying to adjust the tri wing screw for the clicker of my MacBook Pro Mid 2010, I striped the screw. I could possibles drill out the screw but can't find a replacement screw for it.
Questa è una buona domanda?
Punteggio 2
1 Commento
I also have the same problem. I need to find a replacement screw tri wing size.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Some auto or hardware stores have a compound for stripped screws. You're not holding elephants you just want the screw to stay where you set it. (I'm assuming you can turn the screw to the proper height).
Gasket compound or superglue may also do the trick.
If this answer is acceptable please remember to return and mark it.
Punteggio 1
Aggiungi la tua risposta
Anky sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 460
