Salta al contenuto principale
Released June 27, 2013. Model Number C811.
Why is my phone having trouble charging?
Hello, my Casio Commando is having trouble charging. Some times it charges but other times it will. What should I do to try and fix this ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
If your phone is randomly charging it probably has to do with either the power cord and the micro-usb connection. Try using a different cord to see if that fixes the issue, if not try wiggling the cord to see if that generates a response from the power cord. If none of those work look up the troubleshooting guide on how to replace the micro-usb connector as that is the likely problem.
Punteggio 0
Please i want to schematic casio c811 because this problem ic charger
Punteggio 0
Aggiungi la tua risposta
Justin ward sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 981
