Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2193 Domande Visualizza tutte
Domanda Chiusa
Recovery mode after screen repair?!
Put a new screen on, worked fine, but screen had dead pixels. changed it again, now only shows red itunes logo. tried restoring with two different computers, two different cables, and in and out of DFU mode. Itunes is updated. help?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
did the restore fail or succeed? if it succeeded, it sounds like the home button is pushed down and the phone is booting to recovery mode.
Punteggio 0
4 Commenti:
failed. error 3 most of the time
da
look closely at the board near the battery connector, dock connector, lcd/cameras connector----see if you can find any 'fingernail damage' to the board
da
Seriously cant find any. even compared to a perfect board and they seem identical.
da
ok, and make sure to look under the black sticker at dock connector. Try putting the board in a known good housing and see if it will solve.
da
Try fix iPhone stuck in recovery mode by following these instructions:
http://www.any-data-recovery.com/topics/...
Only one signal click!
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 216
