Salta al contenuto principale
La famiglia Mac mini è stata introdotta per la prima volta nel gennaio 2005.
no boot device found
Hi, guess I have played too much with the Mac Mini. Controller for sound broke bought and installed a new one but this did not fix. Simply no boot device can be found any more. Any ideas.
tks + brgds
Eberhard
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Check all cable connections
Check/swap ribbon cable, if no joy you damaged your logic board
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
Punteggio 1
Try starting up from your optical drive with the system installation disk by inserting the disk and restarting holding down the "C" key. On the second page of the installation disk go to the pull down menu, Utilities, Disk Utility and see if it sees the hard drive. If so run Repair. If not check your cables. If the cables are OK, replace the drive.
Punteggio 1
Aggiungi la tua risposta
Eberhard sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,199
