Salta al contenuto principale
Modello A1418 / Fine 2012 / Processore Core i5 da 2,7 e 2,9 GHz o Core i7 da 3,1 GHz
212 Domande Visualizza tutte
Where is the SSD of the FusionDrive located?
Hello everyone,
I need to change the HDD, because it makes some unusual noises, which is not a good sign.
However I have a 1TB FusionDrive, consisting of a 2,5 inch HDD and a SDD. I already checked several Teardowns and I could not locate the SSD. Is the SSD a part of the HDD like a hybrid drive? ...or is it mounted on the Logic board?
Thank you in advance!
(the thin) iMac Intel 21.5" EMC 2544 with FusionDrive, no SuperDrive
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hi Marco Tust,
The SSD of the Fusion Drive should be located at the back of your logic board, right underneath the CPU where you see a long card-like (resembles of an Airport card). You have to flip over the logic board.
If you want to buy an SSD to replace your HDD, you don't need to take away the SSD in the back of your logic board. You can simply put a new one from your HDD.
Hope that helps.
Punteggio 1
The Fusion Drive is set up at the factory; you never have to fiddle with any settings.
The 1TB fusion drive combines a traditional hard drive with 128 GB of flash RAM to offer both significant storage capacity and enhanced performance.
If this answer is acceptable please remember to return and mark it.
Punteggio 0
Aggiungi la tua risposta
Marco Tust sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 359
