Salta al contenuto principale
The AlphaSmart Pro (Model ALF-C01) combines the accessibility of a laptop with the function of a desktop computer in a convenient keyboard-sized device. Released in 1995, this word-processing device is able to send and receive data from desktop computers.
How can I conserve the battery life of my AlphaSmart Pro?
What are simple tips to make the batteries in my AlphaSmart Pro last longer?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
There are many useful methods in order to conserve the battery life of your AlphaSmart Pro device.
  • One of the most effective methods to conserve battery life is to power off your AlphaSmart Pro, located on the back of the device. If you are not using the device or simply walking away for second, by turning off the device you can drastically improve the overall life of your battery. The amazing thing about the AlphaSmart Pro is that when the device is switched off, the file will automatically be saved. When you turn the unit back on, you will not only be taken back to the original file you were working on, but also to the precise place in the file you left off.
  • If you have an AC adapter for your device, connect it to your AlphaSmart Pro. By having the adapter connected, there is an alternative energy source supplying power to your device. This method relieves the strain on the main battery, which can help prolong the life of your battery.
  • Nothing wears on a battery like extended exposure to high temperatures. Your battery will last longer if used or stored near room temperature. Avoid leaving your device in direct sunlight or in a hot car. In addition, check the battery from time to time to make sure it is not excessively hot. This can be an indication that your battery is malfunctioning.
Punteggio 2
Aggiungi la tua risposta
Nathan Smith sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 264
