Salta al contenuto principale
Modello A1311 / Metà 2011 / Processore Core i5 da 2,5 e 2,7 GHz o Core i7 da 2,8 GHz
432 Domande Visualizza tutte
Domanda Chiusa
Power Supply or Logic Board
Is there a way to determine if I have a bad power supply or logic board in my iMac. When I turn it on there is nothing! I have removed the LCD and when I plug it in there is one green light that is on.
Questa è una buona domanda?
Punteggio 0
1 Commento
Help us help you. The more complete the description of your problem is (in this case some history of when/how/why the PSU is no longer working) the more assistance we can provide, and, the sooner we can provide it..
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You're certain that the mains and cord are good. (First rule of tech troubleshooting - check all the cables starting at the mains).
If you have no trickle light LED #1 then I'd check start by suspecting the PSU.
LED #1
Indicates that the trickle voltage from the power supply has been detected by the main • logic board. This LED will remain ON whenever the iMac is connected to a working AC power source. The LED will remain on even when the computer has been shut down or put to sleep. The LED will turn off only if the AC power source is disconnected or the power supply is faulty.
Testing one of these PSU is very dangerous if you're not experienced. Depending on when and why (lightening strike?) the unit went bad It might be simpler to just replace it.
If this answer is acceptable please remember to return and mark it.
Immagine iMac Intel 21.5" (Late 2009-Mid 2011) Power Supply
Prodotto
$69.99
Punteggio 1
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 172
