Salta al contenuto principale
The Toshiba Tecra M2 model was useful in the business field for its lightweight design and bluetooth capability.
4 Domande Visualizza tutte
Why is my touchpad not responding anymore?
The touchpad isn't responding to anything right now but I can use a mouse in the USB port. How can I fix the touchpad?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
4 Risposte
Risposta Più Utile
Does your laptop have a keyboard shortcut that disables the touchpad? I think off the top of my head Toshiba uses the Function + F9 key to turn on and off the touchpad. Some even had a button right next to the touchpad that performs the same function.
Punteggio 5
Go to Mouse settings>touchpad >additional settings on the right side>>Advanced>advanced featured settings>device select>touchpad>>apply
Punteggio 1
You may need to update the touchpad's driver. Which can found here at the Toshiba Software & Support page
Punteggio 0
1 Commento:
That’s a good idea, but that’s not always the case.
da
One of the issues is that your laptop is old and the laptop dies / runs out of battery, so the mouse pad goes filty and stops working . The only way I’ve found is that you use a usb and connect and mouse to the laptop.
Punteggio 0
Aggiungi la tua risposta
Amber Cook sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 11,080
