Salta al contenuto principale
2.26 or 2.4 GHz / White plastic unibody enclosure
645 Domande Visualizza tutte
Domanda Chiusa
replaced logic board, and still no power
Greetings, I just replaced the logic board in my Macbook with a used, supposedly working board, and put it back together properly, and no power. Mag safe adapter is orange when attached. What is the most likely problem here assuming that the board is good? Power switch bad? If so, can I test it somehow? Or something else? Any info will be appreciated.
Thanks, David
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
I would try replacing the MagSafe board. Its possible the connector is bad.
Are you sure the logic board is good?
Punteggio 2
See this previous Question and Answer.
If this answer is acceptable please remember to return and mark it.
Punteggio 1
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 107
