Diagram of the fuse box
I can't find the trunk fuse on my Pontiac Bonneville
Questa è una buona domanda?
@carson_13, benny,Niki , There are two fuse blocks in your vehicle: the driver’s side and passenger’s side fuse blocks and the 3rd is under the hood engine compartment. I believe trunk fuse to be in fuse/relay box passenger side under dash(may be able to access easier by removing glove box liner). Radio fuse shows position 8D, Driver’s side fuse interior block, Pg.6-62/6-63, in the manual link posted below. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Were would the window fuse be located at in the driver side one or the passenger side fuse boxs
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 33
Tutti i Tempi: 6,416
1 Commento
I'm having the same problems. Can't find the same fuse box for the car . radio etc.. Someone help up please. I'm no dumbie when it comes to cars. But I'm stuck. Looked everywhere..
Ok. The small fuses are located under the steering wheel where the brake pedal and gas pedal are at.. As far as where the trunk fuse. I can't help there.
da benny elliott
