Salta al contenuto principale
Released September 14, 2012, Apple's EarPod headphones are a new revision to their iconic white headphones. Model number: MNHF2AM/A.
20 Domande Visualizza tutte
How do I repair a cut headphone cable?
The cable of my Apple EarPods got cut above the mic. I'd usually be able to repair a cable, but because everything inside is so tiny, I can't really tell what's what. Is there a way to repair the cable?
Questa è una buona domanda?
Punteggio 2
2 Commenti
So did the volume button get cut off?
da
No, it was cut above the volume button and microphone. There are only two wires inside the cable, they look like they're wound around a small string, I can't see any insulation, just two differently colored wires.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Yes there is 2 different coloured whiers
Twist the one colour to the corresponding colour other whier.
Heat it carefully.
Then apply a few drops of solder to get it properly.
Cover the whire in electric tape.
Do the same for the other.
Tape the hole thing together.
Hope this helps
Truls
Punteggio 1
4 Commenti:
Thank you, I'll try that!
da
Did that work???
I tried for Sennheiser Ear phones.. But it didn't...
I have joined Red and Green as one and the other Copper wires as one.
Please let me know if I am doing wrong.
da
My iPhone cables are damaged below mic what should I do ?
da
I Have A Minor Cuts Becoz Of That I Have To Insert My Earphone For 5-6 Time To Enable My Microphone.Becoz My Microphone Doesn’t Start
da
Aggiungi la tua risposta
Sophia sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 23
Tutti i Tempi: 16,968
