Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Domanda Chiusa
Flickering Black Lines Still After Replacing Screen 3 Times
After replacing the screen 3 times I still get the same problem. How do I fix this? I hope it's not the phone. The flex cable on the screen looks fine, the port on the motherboard looks fine and everything else on the screen works. I'll attach an image so you can see. Please if anyone can offer any suggestions they will be most appreciated.
Questa è una buona domanda?
Punteggio 0
3 Commenti:
Is it an official apple display?
da
No it is not.
da
Where can I buy one at a decent price?
da
Aggiungi un commento
3 Risposte
Hello this happened when the screen connectors arnt plugged in correctly make sure you push them down on wash corner then right in the centre
Punteggio 0
1 Commento:
I've unplugged and replugged the cable multiple times with the same result
da
You can get a new one here at I fixit or a used original at powerbookmedic.com
I've bought my screen from there they also have a 1 year warranty
Punteggio 0
Won't matter if it official or not after 3 screen changes the chance that a copy screen will do this 3 times is very unlikely try the screens in another iPhone 5 if you can get a friends..
Also look at the pins were the screen connections plug in and make sure none are missing or bent. Post a pic and we can have a look also
Punteggio 0
1 Commento:
The screen connector on the motherboard looks perfectly fine. No cables are bent or missing
da
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 6
Tutti i Tempi: 697
