Salta al contenuto principale
The CFS-204 is a 90's style analog AM/FM radio and cassette tape player. It can be powered by either six C-cell batteries or A/C power from a standard wall outlet.
How can I get the buttons on my radio un-stuck?
I pushed the pause button on my radio and now I can't get it to pop back out. I have tried pushing it several times and it seems to be jammed in a permanent downward position.
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If the button is stuck, try to use something small to clean around the button; it may have dirt built up around it causing it to be stuck. Use something small such as a paper clip or a cotton swab to clean around the button. If this does not work, you may need to disassemble the device. If you need more information, see the link here to our Troubleshooting page.
Punteggio 2
Aggiungi la tua risposta
Brittany Patterson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 34
Tutti i Tempi: 22,577
