Salta al contenuto principale
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
433 Domande Visualizza tutte
Convert dead iMac to a Monitor?
I have a 2008 iMac, and unfortunately the logic board is dead. I already confirmed it's the logic board - the apple store took a look at the device. I wanted to give myself a project and try to convert this to a workable monitor - and primarily set it up to work with an external gaming console (Xbox, etc). Is this even possible? Is this even worth the effort or am I SOL? I hate seeing the Mac gather dust in the garage.
Thanks in advance!
Questa è una buona domanda?
Punteggio 0
1 Commento
Can you get a number of the LCD panel itself?
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
The Answer I hope is yes. I have a controler board NT68676 2A 1256 which has vga hdmi and
dvi-d inputs with audio. a simple 4 button control board plus a cable to go between the controller and LCD panel cost around $30 from ebay.com cost me a bit more as I am in UK.
The above controller is normaly use for smaller panels and supplies 12v to power the inverter for the LCD panel. I asked the supplier if I could provide the 24v for the iMac inverter would his controller board be able to handle the signal side of things, he's said it would.
I am looking with no luck yet to find the pinout for the power supply as from the work done on earlier versions G5 and 20 inch it would seem I will have to ground 1 pin on power supply to switch it on. if anyone knows the answer or has already done this would be most grateful if you could share it.
Update
I have today found this pinout from a power supply in the off state but possibly faulty, so if any one could supply pin out for the on state would be great
PIN V
1 GND
2 +12
3
4 4
5
6 GND
7 GND
8 +12
9 +12
10 +12
11
12 GND
Punteggio 0
Risposta Più Utile
If you are talented and experienced with small electronics it is feasible. 'Personally - I would sell the machine as is on Ebay take that $ and put it towards a working x-box.
If this answer is acceptable please remember to return and mark it.
Punteggio 1
Aggiungi la tua risposta
Ed Hsiu sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,774
