Salta al contenuto principale
The GravityLight is a gravity generated light source that involves the movement of weights to power a LED bulb.
Why do the bags of rocks not move?
I have filled both bags of rocks and the bags won’t move. I tried to empty out the bags and refill them, but that still didn’t fix my problem.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Stripped gears are the likely cause for the GravityLight to become jammed. Since the gears are damaged and cannot mesh properly, the gears will become stuck. The gears will need to be replaced by removing the front panel and the frame. Instructions on how to access the gears can be found in the Internal Gear Replacement guide.
Punteggio 1
Aggiungi la tua risposta
Jamie Forslin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 367
