Salta al contenuto principale
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526 Domande Visualizza tutte
Headphone icon still showing after disconnecting from mainboard
Hi all!
I have a rare problem.
I have a Galaxy S4 (i9505) wich had a little bit water damage. After the damage i opened it up and cleaned up some corrosion with isopropanol. After i reassembled the phone it works fine except the part that the headphonejack seems to be connected.
When i disconnect the headphonejack it keeps telling me that it's connected.
I even tried a new HP connector, with still the same problem.
Did i miss a part of the mainboard to clean? The connector on the MB is clean, even tough a connector seems to be a little bit black tough..
I hope someone has a solution or seen the same problem..
Tnx!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
The same, cleaned it but without success. You can flash you phone with CyanogenMod firmware: 11-20140217-NIGHTLY-jfltexx
It helped me, I can use my phone!
Punteggio 0
i9505 headphone icon allways stile
Punteggio 0
Aggiungi la tua risposta
Gadget Fix sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 280
