Salta al contenuto principale
Processore dual core Intel i7 da 2,2 GHz (Turbo Boost fino a 3,1 GHz) o quad core Intel Core i7 da 2,5 GHz (Turbo Boost fino a 3,7 GHz) con 6 MB di cache L3 condivisa.
Damaged display
My LCD Panel tore in the lower right corner (diagonally). It is functional in the rest of the display. Can I modify the display to only use the remain section (programmatically)? That is, project the image to a smaller area of the LCD.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Ouch!
Sadly there is no real way to alter the image area so only a section of the LCD is used for the desktop. But you can leverage the given applications window so its over to one side. From what you describe that is not what you want.
Your other alternative here is to use an external monitor until you can get your system repaired.
Sorry ;-{
Punteggio 1
Aggiungi la tua risposta
barry sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 368
