Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
replace iPhone5 home button with iPhone5s home button
hey there
can the home button from an iPhone 5 be replaced with the fingerprint home button from the 5s and will it work?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
If you're asking for a fingerprint sensor, for you i5, then no. Swapping these parts won't work, for that purpose. If you're going cosmetic, then you can strip and fashion an i5S home button for this, or as Andrew pointed out, purchase one from eBay, that has this particular purpose already in mind
Punteggio 1
Risposta Più Utile
Nope won't work
completely different
Punteggio 1
the answer to your problem is to search eBay for "5S style home button". you can get ones that look like the fingerprint scanner (made of glass and aluminum) but don't actually do anything beyond regular iPhone 5 home buttons. I offer these to all my repair clients, they are a really nice improvement on the original plastic buttons.
cheers
Punteggio 1
Aggiungi la tua risposta
Sanjay Gopal sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 103
